it is interesting
Posted by LeeG on Jan 6, 2005
when glass/epoxy is used where it's not needed or not used where it's needed. If you make up a couple test joints using 4mm okoume panels meeting at a 120degree angle and try different glassing schedules on the interior/exterior it's surprising to find out that the amount of glass on the fillet isn't as significant as the amount of glass on the wood regarding failure modes in kayaks.
In Response to: Right on. by CLC on Jan 6, 2005
- Re: it is interesting by Mark Camp on Jan 7, 2005
- Re: it is interesting by LeeG on Jan 7, 2005
