Re: Sealine springloaded
Posted by CLC on Jan 5, 2005
>>>>Just think if CLC had a skeg kit based on a spring loaded hydrodynamic fin that could fit in every CLC kayak?
Like I said, we're studying it. That would be really cool, though expensive.
The strength of the CLC through-deck installation is the reliability and access to parts for maintenance.
>>>>>> I heard the plastic blade on the CLC skeg would break at the pivot hole if the kayak was jammed repeatedly onto a rack,,is it still the same design blade?
We broke the pivot hole on the very first one (white Chesapeake 17), then changed the geometry to fix it. The production blades have done beautifully.
CLC Skeg Kit
In Response to: Sealine springloaded blad by LeeG on Jan 4, 2005
