More Air Bubble Questions
Posted by Parke on Jan 3, 2005
Would glassing at a higher temperature (70 F) eliminate the air bubbles?
I noticed as the bubbles developed, I could lightly scrape them out with the squeegee or even use a brush. Is this proper?
At this point you may be wondering how I got into this mess? Unfortunately, glassing the bottom took more time than I thought. I had to leave and by the time I got back more bubbles had developed and the epoxy had cured.
Parke
- Re: More Air Bubble Quest by Shuswap Pat on Jan 3, 2005
Re: More Air Bubble Quest by terry on Jan 4, 2005
- Re: More Air Bubble Quest by Doug Judd on Jan 4, 2005
- Re: More Air Bubble Quest by Kurt Maurer on Jan 4, 2005
- Re: More Air Bubble Quest by Josh Ratty on Jan 4, 2005
- Right On, Josh! by Kurt Maurer on Jan 4, 2005
- Re: More Air Bubble Quest by Robert N Pruden on Jan 7, 2005
