Re: First Kayak Air Bubbl
Posted by Parke on Jan 3, 2005
I'll definitely try the syringe route.
Would glassing at a higher temperature (70 F) eliminate this problem?
I noticed as the bubbles developed, I could lightly scrape them out with the squeegee or even use a brush. Is this proper?
At this point you may be wondering how I got into this mess? Unfortunately, glassing the bottom took more time than I thought. I had to leave and by the time I got back more bubbles had developed and the epoxy had cured.
In Response to: Re: First Kayak Air Bubbl by terry on Jan 3, 2005
