Re: Underside deck glass
Posted by BobE on Dec 24, 2004
LeeG, what glass schedules have you seen used on the inside/underside of the deck in boats like the Artic Hawk or other S&G when no deck beam is used permanently? The inside of the hull is one layer with reinforcements at the foot peg rails, heels and hip braces. Use a similar concept for the bottom side of the deck with reinforcement in the area of the original beam location?
In Response to: Re: You can install after by LeeG on Dec 23, 2004
- Arctic Hawk by LeeG on Dec 24, 2004
