Re: Thanks for the info..
Posted by LeeG on Dec 23, 2004
just to set your mind at ease, the "design spec." for bulkhead dimensions was based on one or two first time constructions with the variation possible in those two. A first time prototype bulkhead would be cut from a drawing but it was often re-cut according to what fit in the first time construction. That doesn't mean those first two constructions represent the entire range of possible fittings of a few dozen constructions by first time builders working with different density sheerclamps or different wiring sequences. You could have a Ch18 that was 24" wide or 25" wide without any difference in handling or appearance.
In Response to: Thanks for the info... by Greg G. on Dec 23, 2004
