Re: You can install after
Posted by Ken Leffert on Dec 22, 2004
Greg, sounds like you've got it well under control. I would hesitate a little bit at putting the rear bulkhead 2" back, though. In my case, I often sit on the rear of the cockpit opening getting in and out of my boat, the rear bulkhead being pretty much right under the rear of the cockpit coaming provides a lot of needed support.
In Response to: You can install after.... by Greg G. on Dec 22, 2004
- Re: Moving Bulkhead Aft. by terry on Dec 23, 2004
- Re: Moving Bulkhead Aft by terry on Dec 23, 2004
- Re: You can install after by LeeG on Dec 23, 2004
Re: You can install after by terry on Dec 23, 2004
- Re: 4mm coaming by terry on Dec 23, 2004
- Re: 4mm coaming by LeeG on Dec 23, 2004
Re: Underside deck glass by BobE on Dec 24, 2004
- Arctic Hawk by LeeG on Dec 24, 2004
- Thanks for the info... by Greg G. on Dec 23, 2004
- Re: Thanks for the info.. by LeeG on Dec 23, 2004
- Re: Thanks for the info.. by Mac on Dec 23, 2004
