Re: bulkheads -NO!!!!!
Posted by Rick on Dec 21, 2004
You definitely need to stitch in the bulkheads prior to filleting. All panels and bulkheads are first wired up and then you check for twist and get everything properly aligned. Then fillet the entire structure together in one step. Placing the bulkheads later would add nothing to helping for them hull shape.
Rick.
In Response to: bulkheads by ray on Dec 21, 2004
- Re: bulkheads I wonder?? by epc prez on Dec 21, 2004
Re: bulkheads I wonder?? by ray on Dec 22, 2004
- Re: bulkheads I wonder?? by FrankP on Dec 22, 2004
- Re: bulkheads I wonder?? by terry on Dec 22, 2004
- Re: bulkheads I wonder #2 by epc prez on Dec 22, 2004
- You can install after.... by Greg G. on Dec 22, 2004
- Re: You can install after by Doug Judd on Dec 22, 2004
Re: You can install after by Ken Leffert on Dec 22, 2004
- Re: Moving Bulkhead Aft. by terry on Dec 23, 2004
- Re: Moving Bulkhead Aft by terry on Dec 23, 2004
- Re: You can install after by LeeG on Dec 23, 2004
- Re: You can install after by terry on Dec 23, 2004
- Re: 4mm coaming by terry on Dec 23, 2004
- Re: Underside deck glass by BobE on Dec 24, 2004
- Arctic Hawk by LeeG on Dec 24, 2004
- Thanks for the info... by Greg G. on Dec 23, 2004
- Re: Thanks for the info.. by LeeG on Dec 23, 2004
- Re: Thanks for the info.. by Mac on Dec 23, 2004
