Staining Strips First
Posted by Lloyd on Dec 21, 2004
This quote is from the Green Valley reference and gets to one of my big questions.
Ted Moores in "Kayaks You Can Build" stains then seals with epoxy. Latter when one applies the fiber glass sanding is necessary for bonding. That must be done very carefully or stain will be cut into.
This is the step I most worry about, but I can go to paint if that doesn't look good.
In Response to: Re: Staining by Dave Houser on Dec 21, 2004
