Re: decorative cloth
Posted by Steve Miller on Dec 13, 2004
Do a test panel with some cloth overhanging the edges. Then after the epoxy is fully cured try to tear off the cloth. You will quickly find out how well the idea bonds to your boat. Next do your varnish and go over the deck with some 600 grit wet sandpaper and lots of water. It will knock the gloss off and leave most of the varnish there. Paints have agents to add to gloss paint that make if flatter or less glossy. Not sure about varnish however.
In Response to: Re: decorative cloth by gober on Dec 13, 2004
