Re: Amount of epoxy neede
Posted by LeeG on Dec 9, 2004
It's plenty. The less you put on, the less you have to remove. That doesn't mean don't put on adequate fill coats it means confining the size of the fillets, mixing only what you need for each operation. Make SURE your pumps are accurate for small quantities,,use syringes for small batch measurments so crucial gluing isn't screwed up by poor measurments in one pump quantities.
In Response to: Amount of epoxy needed by Peter Breeze on Dec 8, 2004
