Re: Double - 'flat' deckb
Posted by Paul on Dec 8, 2004
I scrubbed the flat deck beam and installed a full 4mm bulkhead instead. This obviously seperates the cockpits ,so if one cockpit gets flooded the other(hopefully) is dry. I intend to install an electric pump in one of the cockpits,probably the rear ,with a sealable tube connecting to the front cockpit. If the rear cockpit is flooded,turn on the pump. If the front cockpit is flooded,pull the bungie held rubber stopper from the tube and the contents of the front cockpit flows into the rear to be pumped out. Still in design stage at the moment.
Cheers Paul
In Response to: Double - 'flat' deckbeam by Gary Turner on Dec 7, 2004
