Re: bubbles in epoxy coat
Posted by leeG on Dec 6, 2004
ok,ok,,,using the tip of a foam brush to take out bubbles,,it's a fast way to use a roller to lay on an even coat then use gentle pressure of a 2" foam brush to take out the bubbles. In glassing the kayaks there's the "dump and squeegee" crowd or the "roll and squeegee" crowd. Either crowd is willing to tip.
There's cross-over in painting with "roll and tip" so you don't have to become an expert with a $60 Tibetan yak hair brush when applying paint or varnish. Actually I don't know if yaks make brushes.
In Response to: Re: bubbles in epoxy coat by leeG on Dec 6, 2004
- Re: bubbles in epoxy coat by Parke on Dec 6, 2004
- Re: bubbles in epoxy coat by leeG on Dec 6, 2004
- Re: yak brushes by terry on Dec 6, 2004
- Terry's Final Word by Mac on Dec 6, 2004
