Re: Shop tip: micro-ballo
Posted by Lance Alldrin on Dec 2, 2004
If you have pin holes in the primed fiberglass you can simply "squeege" the primer on. Regardless of the type of primer, how its meant to be applied etc. it works by forcing the primer into the pin holes.
I have found that the epoxy/micro mix tends to sag terribly on sloped or vert surfaces. A blend at 6 parts micro to 1 part silica thickener will give an easy sanding mix that doesn't sag. I have faired "acres" of hull surface on the large ocean going multihulls I used to build and this mix works great.
Good luck on your project!!! :)
Lance
In Response to: Shop tip: micro-balloons by jahrome on Dec 1, 2004
Fall Kit Sale 2016
