Re: epoxy coats
Posted by Chris on Nov 18, 2004
Steven, Have you lightly sanded this area to remove high points. (with out the light sanding, the epoxy puts the same amount of epoxy on both the high and low points, so if you sand off the high points you'll get an even finish), When you run your hand over it, can you feel the weave? Have you done the spit test? (spit on the area and rub the wetness around with your finger, if the weave disappears and you can't feel it, I'd say you're good to go. cj
In Response to: epoxy coats by Steven Laughmiller on Nov 18, 2004
- Re: epoxy coats by Tom M. (MD) on Nov 18, 2004
