Re: How cold can you epox
Posted by LeeG on Nov 15, 2004
read more,,my experience is that glassing at 50degree temps isn't worth it. The epoxy is thick and doesn't squeegee easily. I think you need to get the epoxy above a certain level to get a full cure,,full enough to sand or coat with varnish. At 40degrees I think it'll take a couple weeks for MAS to get hard enough to sand.
In Response to: How cold can you epoxy? by Aaron J. on Nov 15, 2004
