Re: Bulkhead radius good
Posted by LeeG on Oct 27, 2004
I tried thinning one sheerclamp on a Ch18 just because it was a tighter grain and ran absolutely straight for about 4' while the other side had a slight curve. There's a limit on how much curve you can get at the ends as the 3/4"thicksheerclamp glued to the 4mmply is sprung apart already,,attempting to bend the top edge of the panel even more puts a LOT of tension on the wires holding the end panels together.
In Response to: Re: Bulkhead radius good by mick allen on Oct 27, 2004
- Re: Bulkhead radius good by Terry Mcadams on Oct 28, 2004
- Re: Bulkhead radius good by LeeG on Oct 28, 2004
