Re: Thanks fellows...new
Posted by Mark Camp on Oct 4, 2004
First thing, if it is a bump, is you have to sand it till it is flat with the surrounding surface.
If you are planning to paint, then that should do it. Continue with your second epoxy coat, ie, your first fill coat.
If you are planning bright finish, then after you've sanded it flat with the surrounding surface, do the spit test. If it passes, once again you have solved the problem and can continue with the fill coats.
In Response to: Re: Thanks fellows...new by TomW on Oct 4, 2004
- Re: Thanks fellows...new by TomW on Oct 4, 2004
- Re: Thanks fellows...new by laszlo on Oct 4, 2004
- Re: Thanks fellows...new by Howard on Oct 4, 2004
Re: pulled thread by Dave Houser on Oct 5, 2004
- Re: pulled thread by TomW on Oct 5, 2004
