Re: Lac Thinner will
Posted by Steve Miller on Oct 4, 2004
Again? When did you use it in the first place? No need to use solvent at all. The best wash is water to clean epoxy. Between coats of varnish or paint after wet sanding - just wash with clean water. Think of it as rinsing the sanding dust off. Charlie is right - lacquer thinner will act as a stripper on fresh paint or varnish.
In Response to: Lac Thinner will by Charlie Jones on Oct 4, 2004
- Re: Lac Thinner will by mike noeske on Oct 4, 2004
- Re: Lac Thinner will by Steve Miller on Oct 4, 2004
- I use water by Charlie Jones on Oct 4, 2004
