Re: shortning the beam
Posted by Walt on Oct 2, 2004
There is a more to it than just making the bulkhead narrower. You need to look at what happens to the bottom panels when the bulkhead is narrowed. You are building from plans ,so take the time to draw the new bulkhesds and compair the width dementions of the bulkhead to the mesurment for the botton panel at the same location.I think you will find that you will need to revise the bottom to suit your new width. Good Luck Walt
In Response to: Re: shortning the beam by Ety Bahar on Oct 2, 2004
- Re: shortning the beam by Howard on Oct 2, 2004
Re: shortning the beam by frank underwood on Oct 2, 2004
- Re: shortning the beam by benyamin on Oct 3, 2004
- Re: shortning the beam by J.Schott on Oct 3, 2004
- Re: shortning the beam by craig on Oct 3, 2004
- Re: shortning the beam by frank underwood on Oct 3, 2004
- Re: shortning the beam by Ety Bahar on Oct 4, 2004
- Re: shortning the beam by J.Schott on Oct 4, 2004
