Re: Glassing the hull
Posted by Steve Miller on Oct 2, 2004
Wood flour mixed with epoxy can color the ply differently than just straight epoxy. If you just had straight epoxy bleed through then no worry. Its all too easy to sand through the veneer so sand very carefully. The ply should really need very little sanding before glassing. No way to tell really until you coat the rest of the wood or add your glass since the glass and goo will darken the ply a lot. Its very likely that all is fine!
In Response to: Glassing the hull by TomW on Oct 2, 2004
- Re: Glassing the hull by TomW on Oct 2, 2004
