Re: Hollow blues...
Posted by LeeG on Sep 23, 2004
sounds normal,,the keeline really doesn't have a smooth curve or rocker,,it's a very slightly rockered center section with the last 3' of the ends coming up a little. Combine that shape with a natural tendency for the tensioned sheerclamp and butterfly opened bottom panel to exert pressure and you can immediately get a concaved center section when wiring things up before fixing it. Put some weight in the center then loosen the wires a little while it's hung by the sheer clamps. I used six small bricks to take it out. Putting in wedges requires you to fill the gap. The panels were cut to come together. It can be done without making a big gap down the center.
In Response to: Hollow blues... by jahrome on Sep 23, 2004
- Re: Hollow blues... by jahrome on Sep 23, 2004
