Re: Glassing Deck...
Posted by Chris F on Sep 21, 2004
When I went through this it turned out easier than I expected. I ran a line of blue tape about 1 inch below the hull deck joint. I threw the sheet of fiberglass over the deck and went to town filling it. I didn't worry about the ragged edges. I filled the weave right up to the tape. Most drips and runs were contained on the fiberglass that extended beyond the blue tape.
Once three coats of epox were applied I pealed up the tape and used a sharp knife to cut the fiberglass right along the top of the tape.
I did this in mid -Aug and about that time someone had a great post descibing this with pictures. You might search for it.
In Response to: Glassing Deck... by Jim on Sep 21, 2004
