Re: Yeah, use ext. forms
Posted by BobE on Sep 15, 2004
The simplest, easiest, fastest, most calming method to install a plywood deck is to use external forms. Allows dry runs, adjustments, can be performed single handed. Prevents gaps over bulkheads or dimples on the foredeck. You can add whatever decoration you want after the resin cures.
In Response to: No deck nails? by Jon T on Sep 15, 2004
