Re: tiny bubbles
Posted by Homer on Sep 10, 2004
It seems the rollers always leave the bubbles. I have found success using the tipping out technique. For me this meant after lightly rolling on a thin layer, in a 1 or 2 ft square section at a time, I take a 4" foam brush and lightly draw it in the same direction only, from dry hull across in single lines across the bubbles. I lay the brush down in a dry area and with feather pressure if any, draw it straight across once only in a 4" wide line for the sole purpose of popping all the bubbles. I finish the length, and move down 4" and repeat. It leaves a smooth finish, no bubbles. results are consistently successful.
In Response to: tiny bubbles by terry lob on Sep 10, 2004
- Re: tiny bubbles by Mark Camp on Sep 10, 2004
- Re: tiny bubbles by Chris Taylor on Sep 10, 2004
Re: tiny bubbles by Terry Mcadams on Sep 10, 2004
- Squeegees here, too! by Robert N Pruden on Sep 10, 2004
- Re: Squeegees here, too! by Homer on Sep 10, 2004
- Re: Squeegees here, too! by jennifer & terry on Sep 10, 2004
- Re: Squeegees here, too! by Mike Delchambre on Sep 11, 2004
