Re: Primer problem?
Posted by Danny on Aug 31, 2004
Thanks Steve. The only other priming I have done is the outside of the hull and I used Interlux Pre-Kote (1 part). If I'm understanding everyone correctly, I just need to sand off as much of the primer as possible then paint with the Brightsides. I say Brightsides because I have already purchased it from CLC (Hatteras White was recommended for the Pram hull), but I thinking of returning it and using the Glidden porch paint that others on the forum have mentioned. I know it would looks as glossy, but I afraid the Brightside will chip too much on the bottom of the hull.
In Response to: Re: Primer problem? by Steve Miller on Aug 31, 2004
- Re: Primer problem? by Steve Miller on Aug 31, 2004
- Re: Primer problem? by Terry Mcadams on Sep 1, 2004
