Re: Epoxy/sand/epoxy
Posted by Fine sand pre last epoxy? on Aug 30, 2004
When you are sanding that third coat that filled the weave (prior to final epoxy coat and fine grit wet sand) do you bother to sand past 100 grit, like into 120/220, or just 100 grit sand, wash and then epoxy?
Thanks again, Mischa
In Response to: Re: Epoxy/sand/epoxy by Steve Miller on Aug 28, 2004
Fall Kit Sale 2016
