Re: Epoxy/sand/epoxy
Posted by Chris Taylor on Aug 30, 2004
I apply a final very thin coat of epoxy prior to the final sanding. I apply the epoxy with a plastic squeege and find that it takes only a few onces to do the entire hull. The result is almost like a coat of varnish and is amenable to a light sanding only prior to first coat of varnish.
In Response to: Epoxy/sand/epoxy by Mischa on Aug 28, 2004
- Re: Epoxy/sand/epoxy by Terry Mcadams on Aug 30, 2004
