Re: Least Amount of coats
Posted by Doug Judd on Aug 25, 2004
If you have completed your epoxy work, you can go with no varnish or paint at all. The varnish serves two purposes - protecting the epoxy from ultra-violet deterioration and cosmetic appearance. The amount of sunlight that you are going to experience in a camping trip is not going to present a UV issue, so pack up and go paddling.
In Response to: Least Amount of coats. by Doug Sutton on Aug 25, 2004
