Re: filling weave of glas
Posted by LeeG on Aug 24, 2004
I've applied fill coats with rollers then tipped out the bubbles. If everything is perfect,,oh right,,then two fill coats is sufficient for 4oz cloth and three for 6oz cloth. It looks more uneven and heinous with each fill coat with variations in fill amplified. The fill coats aren't like varnish where each coat is providing successively smoother surface. Just be careful sanding where there is texture.
In the drawing linked below there should be one more layer of epoxy on the glass as sanding down near the glass removes one of the reasons for using epoxy,,it's a hard, waterproof plastic that protects wood AND fiberglass from damage. Go to this website to see what happens when the fiberglass doesn't have a sufficient protective coat.
http://www.clcboats.com/shoptips/shoptips_fiberglass_weave_filled_epoxy.php/cart_id=5e083f62990717c90d93d35852e38cfe/
Go to this website to see what happens when the fiberglass doesn't have a sufficient protective coat http://www.oneoceankayaks.com/Epoxyhtm/epox6m.htm
In Response to: filling weave of glass by David on Aug 24, 2004
- Re: filling weave of glas by SB on Aug 25, 2004
- Re: filling weave of glas by LeeG on Aug 25, 2004
- Re: filling weave of glas by David on Aug 26, 2004
- Re: filling weave of glas by LeeG on Aug 26, 2004
