filling weave of glass
Posted by David on Aug 24, 2004
I'm confused what the texture of the glass should feel like after filling the weave. I've added 3 thin coats to the deck glass - the 2nd and third coats were added so as to be chemically bonded with the first. I used a squegee.
The texture is a little rough and bumpy. In a few spots it's completely smooth like 'glass' but mostly this rough and bumpy texture. Should I add more epoxy to make it smooth or do I have enough with the three coats? Is the bumpiness just epoxy on the cloth as well as in the gaps?
The hull is smoother because I used more epoxy but i'm now wondering if that is all necessary.
So how should the deck feel after epoxying the glass? Am I ready for sanding or do I need more coats?
- Re: filling weave of glas by LeeG on Aug 24, 2004
Re: filling weave of glas by SB on Aug 25, 2004
- Re: filling weave of glas by LeeG on Aug 25, 2004
Re: filling weave of glas by David on Aug 26, 2004
- Re: filling weave of glas by LeeG on Aug 26, 2004
- Re: filling weave of glas by Mark Camp on Aug 25, 2004
