Re: last epoxy coating
Posted by Jamie Hart on Aug 24, 2004
It's fairly humid here. I'm not sure the name of the technique I used, but I basically sanded down the previous layer down to about 150 grit then simply put on the epoxy (which is the epoxy that clc sells - not silvertip) Thanks, Jamie
In Response to: Re: last epoxy coating by Mark Camp on Aug 24, 2004
- Re: last epoxy coating by LeeG on Aug 24, 2004
