Re: Chesapeake or North B
Posted by FrankP on Aug 23, 2004
The NorthBay is a nice boat that weathercocks pretty significantly. The chessy will do less of that. The chessy will also feel quite a bit roomier (I felt like I was in a tub) and may have more windage issues. (I can't say for sure as wind was light on the days I tested them.) The Chessy will feel much more stable and handles well. The NB will be faster "off the line" and feel quite a bit tippier, but once you get used to that it handles well too. The Chessy has a higher volume and will hold more gear.
I bought the hatch kits for my NB and then didn't use them. I made flush hatches. The hatch kit is the standard with the lip on the deck and plywood underdeck supports/reinforcements. Personally, I don't like the hatches that stick up like that, but you may. The NB doesn't have a flush hatch option, whereas the Chessy does. Both can be made to have flush hatches pretty easily, even without kits.
FrankP
Growing old is inevitible, growing up is optional. Live well, play hard.
In Response to: Chesapeake or North Bay? by Dave on Aug 23, 2004
- Re: Chesapeake or North B by Steve C on Aug 23, 2004
Re: Chesapeake or North B by FrankP on Aug 24, 2004
- Re: Chesapeake or North B by LeeG on Aug 24, 2004
