Re: Stitching on inside h
Posted by Carl Albright on Aug 19, 2004
Probably doesn't matter much, but what I did was before putting the fillet in, I pushed on the copper wire with a screwdriver, to bend the wire in towards the joint. Instead of the curve, you end up with a shallow V-shape pointing towards the joint. Fillet can be smaller then. Lighter boat is better.
In Response to: Stitching on inside hull by Dave on Aug 19, 2004
Fall Kit Sale 2016
