Re: Removing tape remnant
Posted by TomS on Aug 18, 2004
Chemical approach: I've had pretty good luck with "Goo Gone", available at most supermarkets. http://www.magicamerican.com/products_gg.shtml
Mechanical: Try a good sharp scraper. Scrapers, especially the carbide ones (Sandvik makes one, also one from Veritas) are wonderful for shaving down the inevitable bumps, waves and dribblies in the epoxy coat that you want to remove before finishing. I found that shaving off the major lumps of gunk before sanding saved lots of time.
In Response to: Removing tape remnants by Homer on Aug 18, 2004
- Re: Removing tape remnant by Laszlo on Aug 18, 2004
