Re: Epoxy is peeling
Posted by Howard on Aug 18, 2004
wow...never seen that before... when i look at your picture...you have West System and what looks like System 3 on your workbench...did you switch formula's between batches? West System will create an amin blush...and must be cleaned and sanded before recoating if it is fully cured. i am not sure it is advisable to mix formulas? given how milky cloudy the peeled layer is i think you definitely have some form of contamination. think back...what did you do different between your coats? did you stop building for a while and restart? did you do something else in your workshop between coats that could be a source of contamination?
In Response to: Epoxy is peeling by Doug Sutton on Aug 16, 2004
- Re: Epoxy is peeling by Doug Sutton on Aug 18, 2004
- Re: Epoxy is peeling by LeeG on Aug 18, 2004
- Re: Epoxy is peeling by Mark Camp on Aug 19, 2004
