Yep!
Posted by Robert N Pruden on Aug 18, 2004
Unthickened epoxy will work well to repair the scratches. If the scratches are only through the varnish, assuming you have used varnish, you can also touch them up with varnish. I revarnish kayak each spring, even if the epoxy has been scratched but not deep enough to reach the glass. Hope this helps.
Robert N Pruden
In Response to: Scratches! by Jim Whall on Aug 16, 2004
