Re: Stitching Ches16 ques
Posted by Chris Taylor on Aug 17, 2004
You will not be able to stitch without the spreader stick in place.
I pre-drilled all the stitch holes in the edges of the bottom panels (evenly spaced every 4"). I then drilled the stitch holes in the side panels, immediately opposite the ones in the bottom panels, as I stitched.
In Response to: Stitching Ches16 question by Josh Golladay on Aug 17, 2004
- Re: Stitching Ches16 ques by Josh Golladay on Aug 17, 2004
- Re: Stitching Ches16 ques by Doug Judd on Aug 17, 2004
