Re: Epoxy/Graphite 2nd co
Posted by Lloyd on Aug 16, 2004
Here is my reasoning ... after the first coat of epoxy wets out the fiber glass second and third coats are added within seventy-two hours of one another.
One doesn't sand between these coats.
However, if one waits until the epoxy is cured than sanding is required before painting (and I guess adding another coat of epoxy).
I'm trying to take advantage of the this time when the epoxy will receive another coat and add into the graphite and epoxy mixture.
I may not paint and therefore not sand that area.
In Response to: Re: Epoxy/Graphite 2nd co by Vike on Aug 16, 2004
