Re: Bad Bulkhead Fillets
Posted by Laszlo on Aug 12, 2004
Bo,
Not sure if that's a good idea. Rubbing alchohol is typically 30% water and 70% isopropyl alchohol. Not sure if that's compatible with the epoxy's chemistry.
As mentioned above, I use epoxy to do the same thing. That way I don't have to worry about chemical incompatibilities.
In Response to: Re: Bad Bulkhead Fillets by Bo Williams on Aug 12, 2004
- Re: Bad Bulkhead Fillets by Chris Taylor on Aug 12, 2004
Re: Bad Bulkhead Fillets by Chris Krumm on Aug 14, 2004
- Re: Bad Bulkhead Fillets by David Pemberton on Aug 20, 2004
