Re: Seperating the Fiberg
Posted by J.Schott on Aug 11, 2004
You had better call them because I ran into a problem with not enough deck glass for mine. I was about 2-3 feet short when I cut my deck glass diagonally. There was no way I could have cut it any differently, to make it cover the whole deck. Called them, and they took care of the problem without hesitation. That may be the reason I ran short, there were no labels on mine so I assumed the shorter piece was the cockpit glass. Double check with them before you cut it.
In Response to: Seperating the Fiberglass by Brett on Aug 11, 2004
- Re: Seperating the Fiberg by Al MacNevin on Aug 12, 2004
