Re: Bad Bulkhead Fillets
Posted by Senior wannabe on Aug 11, 2004
Brett,
Either use a thinner mix, or after you've applied the bulky fillets, brush them with epoxy to smooth them.
Ideally, the mix should be as thin as possible and still not sag. It'll be stronger that way and more economical of filler.
In Response to: Bad Bulkhead Fillets by Brett on Aug 11, 2004
