Re: Varnish peeling probl
Posted by Terry Mcadams on Aug 4, 2004
What kind of tape are you using? 3M fineline, for example, is not meant for multi-day application, particularly in sunlight, and it can lift varnish and paint if not removed promptly.
Also, did you wet sand or use a fine 3M pad between coats?
terry
In Response to: Varnish peeling problem by Joe Aubin on Aug 4, 2004
- Re: Varnish peeling probl by Joe Aubin on Aug 4, 2004
Re: Varnish peeling probl by Terry Mcadams on Aug 4, 2004
- Re: Varnish peeling probl by Terry Mcadams on Aug 5, 2004
