Re: Perfect timing
Posted by FrankP on Jul 27, 2004
Chris, I'll be doing the overlap by glassing, then waiting for the epoxy to cure a bit (so that it's still sticky but stiff) then trimming to the desired overlap. Many folks recommend minimal overlap (less than the 1.5-2" proscribed in the manual) and I'll probably cut mine down to about .75 inches as long as that will cover the booboos I made when trimming my deck.
FrankP
In Response to: Perfect timing by Chris F on Jul 27, 2004
- Re: Perfect timing by George on Jul 27, 2004
- Re: Perfect timing by SB on Jul 28, 2004
