Re: prep epoxie for 2nd c
Posted by Terry Mcadams on Jul 27, 2004
Some folks have mentioned water staining on the decks, presumably coming from the inside through decks that only have one underside sealing coat. I've never had this problem, and I only use one seal coat under the decks in the cargo compartments (lightly squeegeed to force it in the grain and remove excess.
I do add an extra seal coat under the deck in the cockpit, as this area gets more wear and water.
Up in Canada, one seal coat is the norm. I've never seen a seal there with two coats.
terry
In Response to: Re: prep epoxie for 2nd c by Peter on Jul 27, 2004
