Re: If you are spraying,
Posted by Niels G. Mortensen on Jul 18, 2004
Steve, you write:
"...Use paint filters and filter every batch you put in the roller pan. Do NOT put the unused paint back in the can since it has lost solvent and will effect the rest of the can and your future results. So don�t put half a quart in the roller pan. Same advice for varnish by the way!"
So, my questions are: do you filter varnish as well? And, what do you use for 'paint/varnish filter'? Does it really make a difference?
Having varnished on and off for almost 40 years, I am still trying to get that perfect finish (sic!) - and was wondering if filtering the varnish just might be that last little thing... -- Niels
Good -- but not perfect...
In Response to: Re: If you are spraying, by Steve Miller on Jul 18, 2004
- Re: If you are spraying, by Steve Miller on Jul 18, 2004
