Re: Chester Yawl
Posted by David Hopkinson on Jul 15, 2004
My advice is to do it! I am finishing up an Annapolis Wherry which is somewhat similar. I also sail RC Sailboats. These projects are much different. If you read through these forums and ask advice prior to starting steps that you may be uncomfortable with along with studying the instructions you won't have any problems. CLC also gives good advice. I din't find anything "delicate" except sanding certain areas of the boat (went through the epoxy a couple of places). The article in Popular Mechanics should give you a good overview of the process also. Go for it!
In Response to: Chester Yawl by Mark Totman on Jul 15, 2004
