Re: adding hatch
Posted by LeeL on Jul 12, 2004
Hello Larry:
First, does this Cape Charles have bulkheads? If not , they will be needed first. Decide upon location, then make cardboard templates coat both sides with epoxy and install with a epoxy/wood flour paste.
Contact CLC about the hatch kits, however you can make your own. I made mine out of 1/4" plywood making a spacer and a lip and using the wood that I cut for the hatch opening for the hatch cover.
Installing a rudder is not problematical as rudders are intended to be installed on finished boats.
This is a simplification, if you need more details please get back with specific questions.
In Response to: adding hatch by larry on Jul 11, 2004
- Re: adding hatch by larry on Jul 13, 2004
