Re: Skinny guy seat & var
Posted by kent knisley on Jul 11, 2004
i'd say open the can, look at it, if it it's not dry or milky or lumpy, apply a test application to a wood scrap with a throw away foam brush, and see how it dries... if it looks ok i'd use it. the main problem would be air getting into the can, and if it was never opened, it should be ok-
a main problem with opened cans is when they are not closed well- the lid must be flush with the can, just as before it's opened. some say it should then be stored upside down so no air can get in.
In Response to: Re: Skinny guy seat & var by Jeffrey Ward on Jul 9, 2004
