Re: deck attaching qustio
Posted by Steve Miller on Jul 11, 2004
That advice always puzzles me. Epoxy thickened enough to be glue should not be running down the side of the boat. Pre-wet the surfaces with unthickened epoxy then mix your glue to mustard or mayonaise thickness. Might ooze but won't run. When the deck is on, scrape any ooze off with a small piece of wood or tongue depressor cut off square. Likewise any drip can be wiped off with a paper towel. Work cleanly.
In Response to: Re: deck attaching qustio by Doug Judd on Jul 11, 2004
